New Material in the Material Library
  • New Material in the Material Library
    Hello, I need some clarification about how to save a new set up material. My problem is, that the new material is not available in a new created model. I can't find it in the material library.
    I'm using RFEM 5.20.02 student license.
    Hello. Do I understand you correctly: You want to insert a new material into the material library?
    Frank
      Yes, thats what I want.
        Hello. This is how it works: Create a new material and open the material library.
        In the library, find a material that is as similar as possible to the new material. Click on it once in the list.
        find a similar material
        Click on "Create New Material...".
        Create New Material
        Define a new name and enter the parameters and confirm the dialog.
        New name
        The new material is now in the library and can also be used in the new RFEM file.
        New material
          Hello Frank,
          thanks a lot for the information, I will try it out.
            Hello Frank, it's working, thanks!
            By the way, as I'm working is the tensile structures using cables, membrane materials etc, is there a library available with these materials?
            regards Tomasz
              I'm working with RF-Form-finding module
                Hello Tomasz, there are no membrane materials in our database. But what we have are cables:
                Cables
                Please note: Cables have a special non-linearity, the stretching. This is not taken into account in the RFEM calculation.
                  Frank, thaks for yor support!
                  • #10
                    Hey there,
                    i am trying to find the "cable" but i think there is no such thing in the german version, isn't it?!
                    thanks
                    • #11
                      Hello. This is also available in the German version. There it is called "Seil".
                      Material Seil
